Anyone out there running a Cometic HP Headgasket?
Re: Anyone out there running a Cometic HP Headgasket? (FyReo3)
Cometic makes their headgaskets in different thicknesses. Depending on the thickness you order you can retain or lower your compression. I prefer to run stock thickness on the headgasket and lower the compression with pistons.
Re: Anyone out there running a Cometic HP Headgasket? (ITR420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR420 »</TD></TR><TR><TD CLASS="quote">Cometic makes their headgaskets in different thicknesses. Depending on the thickness you order you can retain or lower your compression. I prefer to run stock thickness on the headgasket and lower the compression with pistons.</TD></TR></TABLE>
Well put. I love my cometic HP gasket. Very high quality.
SCE should have used there copper head gasket for pennies. Worthless Piece of *&%$
madman604
06-02-2003 11:09 AM
