knock sensor issue
My friends 97 prelude keeps throwing a cel for knock sensor after running the engine for 15 minutes.Could this be a engine issue or just a sensor issue?
It's the sensor, the knock sensor CEL means that the engine can't find one, most likely needs to be replaced. My 4th gen did the same thing but luckily it was just the guy who helped with the swap had the wrong wires plugged to it.
Happen to know which other plug is the same as the KS one?
Na, if the knock sensor was working and doing it's job and there was something wrong with the motor you'd be getting misfire codes, the knock sensor code means there's something wrong with the sensor itself.
s_vares
Sep 3, 2006 02:54 PM
