Jerky Throttle
Old Jun 14, 2008 | 02:51 PM
  #26
h22_bb4's Avatar
check the idle sensor
first remove the socket from it then see if the car is still the same if the car went good so its the problem
clean it or replace it
Old Jun 14, 2008 | 04:03 PM
  #27
M2B4's Avatar
Default Re: (h22_bb4)
just changed the map sensor with a working one. now its acting worse. when i step on the gas it sputters like its going to die then raises idle. took for a drive very poor drivability.
Old Jun 14, 2008 | 08:09 PM
  #28
silvspeed's Avatar
Default Re: (M2B4)
whenever you checked the tps did you do a sweep and check for an open or a glitch? also ive had tps spec out fine and be smooth, but when under load the voltage will glitch......just an idea
Old Jun 14, 2008 | 08:38 PM
  #29
M2B4's Avatar
Default Re: (silvspeed)
i used the tps from kteller when i did the manifold and cant find my oem. guess thats next think ima look at.
Old Jun 15, 2008 | 03:33 PM
  #30
Arsenal's Avatar
Default Re: (M2B4)
Have you done a simple spark test?
Remove a plug at a time, place it in the wire, and rest it on the valve cover (as a ground) and crank the engine over to see if it sparks.
If you have spark in all 4, then you have a fuel problem.
When the car is idling, pull each wire off one at a time, and see if the idle changes for any of the cylinders. It should drop for each one. If it stays the same on a cylinder, then that one is dead.
You can then switch the injectors around, and see which one is not working. Process of elimination.
I am betting its an injector!
Old Jun 16, 2008 | 08:55 AM
  #31
M2B4's Avatar
Default Re: (Arsenal)
yeah i measured the resitance of the injectors all 4 were at 2.5 ohms within spec according to the helms.
Old Jun 16, 2008 | 09:13 AM
  #32
Mike95lude's Avatar
Default Re: (M2B4)
I have a similar problem, mine only happens within the first couple minutes of driving. Is yours the same in that regard? Or can it happen after driving for a quite a while? I kind of have feeling its the fuel pump....I've just been too lazy to figure it out.
Old Jun 16, 2008 | 09:20 AM
  #33
M2B4's Avatar
Default Re: (Mike95lude)
mine happens all the time. fuel pump didnt do it for me. honda wants 79.99 per hr to look at it.....
Old Jun 16, 2008 | 03:52 PM
  #34
Arsenal's Avatar
Default Re: (M2B4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i measured the resitance of the injectors all 4 were at 2.5 ohms within spec according to the helms.</TD></TR></TABLE>
Just because there is res. doesn't nec. mean that they are working right.
Have you at least done a cylinder test to make sure that it is not firing right on all cylinders, and not just one??
It's easy to do, just pull the wire off of a plug whilst it's idling. Lie before, if it dips that cylinder is fine, if not that one is dead.
Old Jun 16, 2008 | 08:03 PM
  #35
jabarty's Avatar
does this happen while the engine is cold only or even after its been running awhile? whatever it is, you should diagnose before you swap old, still good parts for brand new parts..itll make a lasting impression on your wallet
Old Jun 16, 2008 | 08:26 PM
  #36
M2B4's Avatar
Default Re: (jabarty)
i did the pulla plug test when i 1st had the problem and again after you mentioned it all made the idle drop on all 4 so that checked out. and the problem is there cold or warm. i am noticing since i changed the map sensor i can smell light fuel at the muffler so its not being burnt.
Old Jun 17, 2008 | 07:20 AM
  #37
JT's Avatar
JT
I would try another TPS and set the voltage corrrectly for close and open, then verify sweeping voltage as well.
Old Jun 18, 2008 | 02:16 PM
  #38
89 prelude si's Avatar
I think i have the same problem in my 89
Sorry i cant say anything more useful but I'll post if I get some useful info
Old Jun 18, 2008 | 04:00 PM
  #39
m00nr0ck Si's Avatar
Default Re: Jerky Throttle (M2B4)
Im curious to see the outcome of this problem because I noticed today that when Im cruising at 45-60 mph mine does a slight jerk back and forth .....it gets really annoying
Old Jun 28, 2008 | 06:38 AM
  #40
M2B4's Avatar
Default Re: Jerky Throttle (m00nr0ck Si)
and the verdict is in (i hope) Things that were fixed: New thermostat sensor, adjusted idle was out of spec, and a new tps fixed the issue.
I bought my tps that went bad from kteller 6 months ago....still no reply from them. I dont know anywhere else i can buy a tps omni doesnt sell 1 for our cars. Im using my old oem one now but i need a gaket any one know where i can mabye just find a gasket? Hate to have to order another tps from kteller knowing that it lasted 6 months.
now to get a new rear wheel bearing...
Old Jun 28, 2008 | 07:02 AM
  #41
Acidcrakker's Avatar
You can use that gasket maker stuff you pick up at autozone. I use that stuff when my old gaskets begin to flake off.
Old Jun 28, 2008 | 07:08 AM
  #42
M2B4's Avatar
Default Re: Jerky Throttle (Acidcrakker)
yeah using some of that now but would rather have a new gasket. found a shop that had 1 day shipping for a tps so hopefully itll be here tuesday get this car running again. thx for all the help h-t
Old Jun 28, 2008 | 07:31 AM
  #43
A Blue Lude's Avatar
TPS gasket?
Old Jun 28, 2008 | 07:32 AM
  #44
M2B4's Avatar
Default Re: Jerky Throttle (A Blue Lude)
a tps /w gasket.
Modified by M2B4 at 10:38 AM 6/28/2008
UKintegra
Jun 8, 2011 12:32 PM
ITR010342
Acura TSX
Jun 23, 2010 08:45 AM
mouab18c1
Engine Management and Tuning
18
Jun 3, 2010 10:57 AM
Purple-skunk
Jul 25, 2009 04:12 PM
ActiveAero
Jul 6, 2005 11:37 PM
