installing tach
Old Sep 18, 2002 | 12:46 PM
d15nonvtec's Avatar
Default installing tach
hey my friend had a 93 prelude with the 2.2 vtec motor. he wants to put a tachometer in his car, an autometer one, but i cant find the wire that you use to hook up to the tach. on my civic its the dyagnosic tach wire on the drivers fender well. is the prelude the same? any info would be greatly appreciated thanks
Old Sep 18, 2002 | 01:01 PM
Cottonwoodz's Avatar
Default Re: installing tach (d15nonvtec)
Its a blue capped wire on the passenger side, by the strut tower.
Old Sep 18, 2002 | 01:10 PM
ViZ's Avatar
ViZ
Default Re: installing tach (Cottonwoodz)
I confirm that
Old Sep 18, 2002 | 07:12 PM
d15nonvtec's Avatar
Default Re: installing tach (ViZ)
cool thanks guys, looks like i gots something to do tommorrow!
Old Sep 19, 2002 | 09:52 AM
IA93Vteclude's Avatar
I use the blue capped wire for my shift light (autometer) and it not as acurate at high RPM. Or does that mean that my stock tach is not accurate. For like 7400 on my stock tach, I need to use the 7000 RPM pill just to turn on a 7400 also. Whats that all about.
Old Sep 19, 2002 | 10:48 AM
4bidden's Avatar
Default Re: installing tach (IA93Vteclude)
so basically your stock tach is showing 400rpm higher than actual?
Old Sep 19, 2002 | 10:58 AM
Default Re: installing tach (4bidden)
I'm not sure which one is acurate. Because I have hit the fuel cut off at the right RPM on my stock tach. I'm thinking that the blue cap tach out put is not acurate, I'm thinking that it is only use for low RPM read outs. But I don't know which wire to hook it up to on the external coil.
MYGODREPENT
Mar 11, 2010 06:04 PM
Mikey3000
Sep 6, 2006 02:32 PM
JDM_Andrew
Oct 8, 2005 07:20 PM
supertrogdor
Mar 29, 2004 07:28 AM
FR-MOB: ThE bEe GuY
12
May 6, 2003 12:45 PM
