problem with key in ignition
Old Jan 9, 2005 | 11:54 AM
qcktegls's Avatar
Default problem with key in ignition
this weekend i went to go somewhere and when i put the key in the ignition and tryed to turn it over it would not go. the wheel was locked but i tried for about 10 min to turn it over many many times and it would not go. finally it gave way and started. now it does it every once and a while if the wheel is locked or not. nebody have ne suggestions on what this could be? thanks
Old Jan 9, 2005 | 11:56 AM
SiR Inspired ED7's Avatar
Default Re: problem with key in ignition (qcktegls)
are you sure ur key is not messed up?
Old Jan 9, 2005 | 02:21 PM
g2xsi's Avatar
could be the ignition assembly..
Old Jan 9, 2005 | 02:40 PM
qcktegls's Avatar
Default Re: problem with key in ignition (92 DA B16a)
yeah im sure the key isnt messed up because i tried my spare key which ive never used before
Old Jan 9, 2005 | 02:43 PM
Nekekami's Avatar
had the same thing go wrong with a 76 Scout I built for a buddy of mine, ended being the lock cylinder. Any locksmith should be able to just come out to your car and fix it on the spot, took me all of ten minutes.
Old Jan 9, 2005 | 03:52 PM
qcktegls's Avatar
Default Re: problem with key in ignition (Nekekami)
alright ill get to one. thanks. for now i can live with it cause even when it does lock i can get it to start after some jolting.
minguswooten
Honda Civic (2001 - 2005)
Oct 8, 2021 07:46 AM
Binarymasta
Sep 14, 2012 02:02 PM
exz0n-.-
Oct 23, 2008 04:57 PM
dc2go
May 23, 2005 10:33 AM
Hazem
15
Dec 16, 2004 01:54 PM
