how to tell if shocks are blown or not
Old 06-09-2005, 10:19 AM
krnfly2damoon's Avatar
Default how to tell if shocks are blown or not
how can you exaactly tell if your shocks are blown or not?
and also, my front part (i think its from suspension) makes really slow and low rattling sound only in the morning when its cold. it sounds like a baseball hitting my suspension. does anyone know if its suspension or not and what i should do?
Old 06-09-2005, 11:04 AM
mafia's Avatar
Default Re: how to tell if shocks are blown or not (krnfly2damoon)
my shot is out, and the top of it has a crap load of greas on it... and its all mesed up
Old 06-09-2005, 11:05 AM
Wiseguy619's Avatar
If they are leaking.
Old 06-09-2005, 11:17 AM
kablamo's Avatar
leaking is a clear sign
if your shocks are gone the car will be bouncy over bumps... since only the spring is holding the car, and the purpose of a shock is to dampen the up and down motion of the spring.
Old 06-09-2005, 12:08 PM
2point3h22lude's Avatar
To test your shocks, try this:
Bounce the car by pressing down one corner of the car few times then give it a good push then let go.
If your car still has good shocks, it will go up then down just a little bit, then stops moving.
If the shocks are bad, on the last push after you let go, it will go up, then down, then up again before coming to a stop.
Any sign of leak around the inner part of the shock definitely tells you that it's time to replace the shocks.
Old 06-09-2005, 02:55 PM
Default Re: how to tell if shocks are blown or not (2point3h22lude)
thx so much!
Old 06-09-2005, 03:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krnfly2damoon &raquo;</TD></TR><TR><TD CLASS="quote">thx so much!</TD></TR></TABLE>
You're welcome
Old 07-18-2005, 09:36 PM
x_tc-Dae's Avatar
If your shocks are blown and you are just riding on your springs, would the spring could also be damaged?
Old 07-19-2005, 09:12 AM
psilo's Avatar
Default Re: how to tell if shocks are blown or not (ghost face)
^i also would like to know the answer to this, i bought my car lowered on H+r sports and stock shocks, they're most definately blown especially by now, how do you think the springs would be?
Old 07-19-2005, 09:21 AM
BA5
BA5's Avatar
Default Re: how to tell if shocks are blown or not (psilo)
Blown shocks will not damage your springs.
Old 07-19-2005, 10:56 AM
syntax.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghost face &raquo;</TD></TR><TR><TD CLASS="quote">If your shocks are blown and you are just riding on your springs, would the spring could also be damaged? </TD></TR></TABLE>
Riding on blown shocks will not damage youre springs, but it will cause additional stresses on other suspension parts, such as ball joints, tie-rod ends, bushings etc.
go_b16_go
06-14-2009 02:21 PM
hybrid90
Suspension & Brakes
15
03-21-2009 06:33 AM
KevronsEG
01-31-2002 05:47 PM
sLo B18b
06-23-2001 04:12 PM
Quick Reply: how to tell if shocks are blown or not
