how to save an engine from boost?
Old May 16, 2003 | 09:09 AM
Arch-Angel's Avatar
Default how to save an engine from boost?
About to FI my H23a, and probably run 8-10 PSI.
I know its not all that high, but it's done a few miles, and i want to keep it as a daily driver for many years to come...
So whats the best way to go. The turbo kit I am looking at has the option of a MSD Boost Timing master or a new rIdeal Head Gasket.
Which is the safer option? Consider that I am already running it on no less than 98 octane unleaded.
Having said that, I am thinking the Head Gasket, and then if I still get knocking, resleeve the block to 8.5:1.
Does that make ANY sense or am I talking crap??
Old May 16, 2003 | 09:12 AM
Mikeyslude's Avatar
***ECU***
Old May 16, 2003 | 09:18 AM
Arch-Angel's Avatar
Default Re: (Mikeyslude)
Dont get it, how can an ECU prevent detonation? By altering the timing?- But then won't I be losing HP? and isnt that what the MSD does anyway?
Old May 16, 2003 | 12:26 PM
prelittlelude's Avatar
Default Re: (Arch-Angel)
what mike is trying to say is that a tunable ecu is your best safe gaurd. in the world of boost Tunning is EVERYTHING. if you build and ok setup and have a crappy managment system your car won't last long. But you build it ok and have a well done conservitive tune your car could last much longer.
from whati know the MSd just retards the timing for each pound of boost. but with a tunable ecu you can do all that and more.
Old May 18, 2003 | 06:35 AM
Arch-Angel's Avatar
Default Re: (prelittlelude)
ok then, so which ecu to go for?
I guess hondata, but tell me a few more good choices cause I can't get Hondata here!
Old May 18, 2003 | 08:36 AM
Mikeyslude's Avatar
AEM, Hondata, Haltech, Motec, etc
Old May 18, 2003 | 10:14 AM
HaleLude's Avatar
Default Re: how to save an engine from boost? (Arch-Angel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Does that make ANY sense or am I talking crap??</TD></TR></TABLE>
Get the headgasket and a Hondata and tune that mo fo. If you have the money sleeving the block and getting low compression pistons would definetely help
BauleyCivic
Jan 6, 2006 10:36 AM
mozez
Jan 13, 2004 08:48 PM
civictyper85
Apr 11, 2003 06:57 PM
teamrocket si
Jul 6, 2002 12:52 AM
blackitr730
Jun 23, 2001 12:12 PM
