Stumbling problem
Old 09-03-2006, 02:01 PM
asmallsol's Avatar
Default Stumbling problem
On my h22a swap on my 92 Si, I have put about 700 miles on it and have worked out most of the major problems. Most of the time, it pulls hard, however ever once in a while, when I go to accelerate it stubles and feels like there is zero power but with very small spikes in power.
My main realy was bad, however, I resoldered where a solder joint was cracked. Timing has been set correctly.
I am thinking that it may be something with fuel. has anyone else had a problem like this.
Old 09-04-2006, 04:00 AM
asmallsol's Avatar
Default Re: Stumbling problem (asmallsol)
up
Old 09-04-2006, 05:48 AM
sir_drinxalot's Avatar
Check your fuel system is clean, ie injectors, fuel filter etc
might help?
mums old accord did that a while ago, and i think thats what fixed it from memory.
Old 09-04-2006, 07:51 AM
91backinblack's Avatar
Default Re: Stumbling problem (sir_drinxalot)
I have this same exact problem. Like in the morning it will be fine for a few miles, and then it will be all wierd. The car gets louder but i feel as if i am not even acc. I thought i might have a vacume leak. LMK how it goes and i will let you know if i find anyhting out on mine.
Old 09-04-2006, 05:55 PM
asmallsol's Avatar
Default Re: Stumbling problem (91backinblack)
I am going to change out the fuel filter this weekend and then run a thing a fuel system cleaner (although I am still a spectic on that ****) and we will see what happens.
hotbway_jason
11-25-2010 04:27 PM
JUN.
04-06-2008 09:31 AM
94DOHCDELSOL
05-11-2005 11:50 AM
acs97prelude
08-29-2002 07:16 AM
Quick Reply: Stumbling problem
