help!!!!! 93hatch with gsr swap
Old Dec 20, 2010 | 05:57 PM
ek201's Avatar
Default help!!!!! 93hatch with gsr swap
help help help plz anyone this car is driving me nuts im getting fuel to the rail but not in the cylinders i have spark and the pump is well pumping i can hear it but is not firing fuel into the engine so end result it dont run any ideas what it might be
Old Dec 20, 2010 | 09:14 PM
tonythetuner®'s Avatar
Default Re: help!!!!! 93hatch with gsr swap
Could be a bad ecu. If u kno its a good ecu check all your grounds. Make sure the grounds on the termostat are connected. .. and that all your other grounds are connected...
Old Dec 20, 2010 | 09:43 PM
mouab18c1's Avatar
Pull out one of your injectors and turn the key to the on position to see if they are shooting out fuel.
Old Dec 20, 2010 | 10:21 PM
ek201's Avatar
Will be swaping ecus tomorrow to see wat happens cuz pulled the injector out to see if it was pulsing and nothing I also noticed that there was a jumper on the main relay that when I pull it out it cuts out the pump so I bought a new relay an my fuel pump don't work so I will also be swaping in a new fuel pump cuz with the jumper in the pump just constinly pumps fuel to the rail all grounds are good too ill try to post a video clip of wat is doing thank you
project92ex
Oct 25, 2008 11:00 PM
billy_thekid
Jan 5, 2008 06:04 AM
Cameron60
Jan 16, 2007 06:04 PM
mockujin
17
Nov 24, 2002 05:11 PM
