Help!! Lost my Vtec!!!!!!!
Old Nov 14, 2002 | 06:08 PM
hondalude9394's Avatar
Default Help!! Lost my Vtec!!!!!!!
Well, I put some break in miles on my car, after getting it back from the shop. After having it rebuilt and I put in Je pistons 10:1 compression, Eagle rods and a ACT clutch. When i got it there was a check engine light on. It wont flash ANY codes. And i took it into Vtec range and ITS NOT THERE, just as we thought its in limp mode. But we dont know why. Any Ideas??? thanks nick
Old Nov 14, 2002 | 06:47 PM
aklucsarits's Avatar
New User
Default Re: Help!! Lost my Vtec!!!!!!! (hondalude9394)
When the ECU won't report codes, the first troubleshooting step is normally to substitute a known good ECU.
Andrew
[Modified by aklucsarits, 10:48 PM 11/14/2002]
Old Nov 14, 2002 | 06:53 PM
JG Luder's Avatar
Default Re: Help!! Lost my Vtec!!!!!!! (aklucsarits)
it could be any number of problems. first things first, make sure the VTEC sol. is hooked up correctly.
If that isn't it, then 90% of the time it's an oil pressure problem. It could require pulling the head and checking to make sure that none of the passages have been blocked. Happened on mine once.... or twice. Ok, three times, but my head has been off like 20 times. Literally. Velcro owns j00.
Oh, if you have a VAFC hooked up... that would be my first place to go, if not, ignore this sentence.
Old Nov 14, 2002 | 07:08 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Help!! Lost my Vtec!!!!!!! (JG Luder)
if the ECU won't show a code, it's one of 2 things, a wiring problem, or the ECU. if you know that your ECU is good, then you have to go through and double check all your wires, some plugs ARE alike, so it's possible that you've crossed some when re-installing the engine
S_StarGsr
Apr 29, 2017 08:24 AM
civic_b20vtec
Jun 25, 2013 05:27 AM
ari integra
Feb 1, 2012 03:59 AM
turbob16ef
May 7, 2008 11:33 AM
veilsides2000
Nov 27, 2004 11:18 PM
