Jacking Problems
Old Oct 27, 2003 | 04:10 AM
b16egsi's Avatar
Default Jacking Problems
My car is lowered and I cant slide a heavy duty jack under the car so I have to place the stock jack under the jack point and get it up a inch or two.. where can I place the heavy duty jack so I can get the car up higher and then use the jack stands on the jack points
Old Oct 27, 2003 | 04:16 AM
93CivicSI's Avatar
Default Re: Jacking Problems (bcmatzen)
Drive your car up onto a couple of 2x6's to raise it enough to get your big hydrulic jack under it.
Old Oct 27, 2003 | 04:52 AM
b16egsi's Avatar
Default Re: Jacking Problems (93CivicSI)
lol.. good idea!!!!... never though of that but if I use the jack points to jack up the car where do I put the stands
Old Oct 27, 2003 | 05:20 AM
2000blackgsr's Avatar
The stands go right behind the front wheels when jacking up the front, in front of the rear wheels when jacking up the rear. There are bars under the body to show the points.
xerox445's Avatar
well from the back i usually put a 2 X 4 on the top my my jack and jack the back up from the LCA?? probly not, dont know exactly what its called, but i assume its what the LCA is connected to...i would like to call it the "subframe" i guess...anyway, i jack it up from there and then put my jackstands on the stock side lift points, as for the front, i havent put the front on jackstands yet, but i would think it would be similar
Old Oct 27, 2003 | 05:28 AM
TorganFM's Avatar
Default Re: Jacking Problems (xerox445)
we have these steel ramp thingies. just set them down and drive up, then slide the jack under.
Old Oct 27, 2003 | 06:23 AM
axhandler's Avatar
I jack the car up by the tow points in the very front. I use a 2x4 block and I can jack up high enough to get jackstands under the front jack points. I've never had a need to raise it any higher than one notch on my jackstands.
Old Oct 27, 2003 | 11:45 AM
PupaScoopa's Avatar
Default Re: Jacking Problems (axhandler)
I had the same problem and rarely had some 2x4 or 2x6's
I modified my Craftsman "high lift" SUV jack to sit lower. I removed the wheels and replaced them with high-grade washers (stacked together). I do not have access to a machine shop to cut me new wheels nor did I want to drill new holes to situate the axle higher.
It lowered the front of the jack about 1/2 an inch... so if that's all you need to clear your car, try the above.
Whatislove
Honda Civic (2001 - 2005)
16
Jun 17, 2009 08:11 AM
mv10s
Apr 10, 2004 03:59 AM
dclub01
Aug 18, 2003 04:21 AM
Zulu888
Aug 20, 2002 02:47 PM
