help on compression test reading????
Old Oct 19, 2003 | 09:03 PM
Anhjockz's Avatar
Default help on compression test reading????
what numbers should i have on the prelude vtec 4gen
on all four cylinders for it to get good
thanks
Old Oct 19, 2003 | 09:16 PM
4bidden's Avatar
Default Re: help on compression test reading???? (Anhjockz)
Just make sure they're within like 10psi of each other.
Old Oct 20, 2003 | 09:26 AM
accordhybrid's Avatar
Default Re: help on compression test reading???? (4bidden)
I just did mine and they were 225-205-220-210
Old Oct 21, 2003 | 08:01 PM
blackcd's Avatar
mines was 250-250-250-250
Old Oct 21, 2003 | 08:13 PM
solowerks's Avatar
Default Re: (blackcd)
for a h22a1
Nominal 185 psi
Minimum 135 psi
Maximum Variation 28 psi
I check my compression and it is running at 210 psi all the way across.
Old Oct 21, 2003 | 09:54 PM
Monkey Fing a Coconut's Avatar
Default Re: (solowerks)
250-250-250-250
Old Oct 21, 2003 | 10:19 PM
eg:R's Avatar
i don't know why but mine change on me, before it was 210-210-210-210, this was about a year ago, and yesterday now is 250-215-210-210, can anyone let me know how or why it jump like that?
Old Oct 21, 2003 | 11:12 PM
Anhjockz's Avatar
Default Re: (jacklee)
so how much is usually a copmression test and alll...hmmmmm 250psi
well i hope i get that
thanks guys
Old Oct 22, 2003 | 03:16 AM
solowerks's Avatar
Default Re: (Anhjockz)
250 is high
Old Oct 22, 2003 | 04:34 AM
rjr162's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacklee &raquo;</TD></TR><TR><TD CLASS="quote">i don't know why but mine change on me, before it was 210-210-210-210, this was about a year ago, and yesterday now is 250-215-210-210, can anyone let me know how or why it jump like that? </TD></TR></TABLE>
carbon build-up
Old Oct 22, 2003 | 09:30 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Anhjockz &raquo;</TD></TR><TR><TD CLASS="quote">what numbers should i have on the prelude vtec 4gen
thanks</TD></TR></TABLE>
How many miles on the engine
Old Oct 22, 2003 | 03:43 PM
Anhjockz's Avatar
Default Re: help on compression test reading???? (SKDRCR)
the motor has 230k on it and what should i get or what good to get when you have 230k on the motor
thanks
andy
Old Oct 22, 2003 | 06:46 PM
vltnolia's Avatar
El gato en los pantalones. Gub guk. gac mai. du ma mai.
you like horse manuer?
Old Oct 22, 2003 | 07:02 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Anhjockz &raquo;</TD></TR><TR><TD CLASS="quote">the motor has 230k on it and what should i get or what good to get when you have 230k on the motor
thanks
andy</TD></TR></TABLE>
if it has that many miles on it and your above 210 across the board
then it probably has quite a bit of carbon build up.
you should probably get a leakdown test on it b4 you put too much
money into your current engine
boosted k20
Apr 21, 2005 04:55 PM
snowblind7x
Apr 13, 2005 08:12 PM
luckypon7
Mar 16, 2005 08:52 AM
projektCRX
Apr 22, 2004 12:18 PM
Team 4
Dec 5, 2003 03:38 PM
