Heeeeeellllppppp
Old Sep 27, 2002 | 06:15 PM
96LudeSiVTEC's Avatar
Default Heeeeeellllppppp
After the timing and balance belts were installed I started getting a high pitched whine. It sounds like its coming from the timing belt area. From what I was told the balance belt may be too tight. I know the timing belt can't be too tight due to the tensioner being hydraulic. Has anybody else run into this?
Old Sep 27, 2002 | 06:48 PM
PrecisionH23a's Avatar
Default Re: Heeeeeellllppppp (96LudeSiVTEC)
did they mess with the power steering or altenator belts? they might be loose.
[Modified by GudeH23a, 10:49 PM 9/27/2002]
Old Sep 27, 2002 | 07:44 PM
Default Re: Heeeeeellllppppp (GudeH23a)
Yeah they replaced all the accessory belts. I should know something tomorrow they are going to get on it first thing tomorrow morning.
Old Sep 27, 2002 | 07:50 PM
IA93Vteclude's Avatar
Have you found out anything yet? What kind of a whine are you talking about, High pitch, low pitch, and at what RPM's or do you hear it all the time.
Old Sep 27, 2002 | 08:20 PM
satan_srv's Avatar
Default Re: Heeeeeellllppppp (IA93Vteclude)
I just had mine done and it makes the sound....I think it wil go away once the t-belt stretches a little bit...
Old Sep 27, 2002 | 09:24 PM
Cottonwoodz's Avatar
yeap, its the new belt, it will go away.
Old Sep 28, 2002 | 05:17 PM
Default Re: Heeeeeellllppppp (Cottonwoodz)
Okay. Sorry about the late post but being a carsalesman I work long hours.
We checked it today and yes it is from the timing belt being too tight. However there is nothing you can do about it. The belt basically has to set itself. The only recommendation is to recheck the belt for extreme wear after about 100 to 200 miles. As long as there is no extreme wear you are good to go. As far as the whining it should go away on its own in about a week.
By the way THANKS for all the replies.
Old Sep 28, 2002 | 06:02 PM
Quaalude's Avatar
that whine is from the balancer belt being initially too tight....mine does the samething....with time, that whine should go away
ECStarr
Honda Civic (2001 - 2005)
Aug 30, 2012 04:44 AM
airikkCRX
Apr 2, 2010 08:29 AM
SPIKE'S91CIVICSI
Mar 9, 2009 03:11 PM
jongme23
Jun 28, 2007 07:51 PM
migs
Dec 5, 2002 01:28 PM
