H22a VTEC problem
Old Oct 11, 2002 | 01:21 PM
Jago's Avatar
Default H22a VTEC problem
Ok
I swaped a prelude motor into my 94 ex accord.
When I started it up check the engine light came on.
I checked the code, it was a 22 (Vtec Pressure switch)
I replaced it and I am still getting a code 22. Anyone have any
ideas. (will a bad VTEC pressure switch cause VTEC not to engage.
Old Oct 11, 2002 | 02:46 PM
4bidden's Avatar
Default Re: H22a VTEC problem (Jago)
check your wiring and yes it will make vtec not engage
Old Oct 11, 2002 | 04:44 PM
safe driver's Avatar
Default Re: H22a VTEC problem (4bidden)
check your oil
Old Oct 11, 2002 | 05:03 PM
kb58's Avatar
Banned
Default Re: H22a VTEC problem (safe driver)
With the engine running, see if the VTEC pressure switch closes/opens when it should. Helms manual?
Old Oct 11, 2002 | 10:48 PM
mattmw88's Avatar
Default Re: H22a VTEC problem (kb58)
go through and follow the wire from where you added a vtec pressure switch wire during the install and double check everything. Check the ecu to see if it's in the right spot, check the wire itself, and check the actual connecter on the block.
mikejames
Jul 18, 2009 12:58 PM
Eli Mac 67
Jun 6, 2007 05:01 PM
EP-sLYD
Mar 5, 2007 05:29 PM
bburtonsk8r2
Nov 9, 2005 02:16 PM
Gonzo_SiR
Apr 12, 2004 08:28 PM
