H22a Problem
Old Sep 13, 2003 | 03:06 PM
h22a1300177's Avatar
Default H22a Problem
Please help me, I swap a h22a into a 92 Accord, and everything was done! The car runs weird, when I didn't put in the gear, I can rev up to 8,000rpm. But when I try to drive it, (put in 1st gear) the car can only drive 5-10mph (The rpm won't pass 2k, if I step on the gas, it just like nothing, won't move or anything.). 2nd gear the same, won't pass 5-10mph. The only way I can rev the rpm over 2,000 while sitting in gear is press down the clutch. Once I release the clutch, the car will not run again.... until it drop below 10mph. Please help me... what is my problem!!
Old Sep 14, 2003 | 07:25 AM
Anyone ? Please~
Old Sep 14, 2003 | 10:27 AM
Nick H's Avatar
New User
Default Re: (h22a1300177)
are you sure you have the clutch and pressure plate on right?...sounds to me like a mechanical problem if you can rev out of gear but not in gear...
Old Sep 14, 2003 | 03:47 PM
Default Re: (Nick H)
Thanks man, I think I know what is the problem.... I tried it this morning! I figured out something, the car can runs now.
The problem is ...
What is that part call? What it does for the engine?
...... but now the idle is like 1,200 rpm.(too high for normal)
Old Sep 14, 2003 | 09:18 PM
Jago's Avatar
That is your EGR Valve.
Old Sep 15, 2003 | 05:37 AM
what will happend if the EGR valve is bad?
Old Sep 15, 2003 | 09:47 AM
accordhybrid's Avatar
EGR is only emission related alot of the guys outside of Cali take them off and and put a block plate over it all it will do is throw a EGR code.
Accordhybrid
Old Sep 15, 2003 | 09:52 AM
Default Re: (accordhybrid)
Is that OK to runs a car without EGR?(Poor/faster?) Any thing will happend? does it makes any change on idle speed?
Old Sep 15, 2003 | 10:05 AM
KTeller8's Avatar
maybe check your fast idle valve...
sometimes when motors sit, they build up junk and solid mass.. needs to be replaced or cleaned
just a thought??
Old Sep 15, 2003 | 10:07 AM
Default Re: (KTeller8)
Where is the fast idle valve located?
Thanks~
Old Sep 15, 2003 | 10:19 AM
KTeller8's Avatar
do a search for eratic idles, or idle problems..
in the accord section. you ll find a few diagrams.. mine on the h22 is on the intake manifold on the front!!
Old Sep 15, 2003 | 03:30 PM
accordfreak's Avatar
i took my POS EGR out..
btw.. recently I was having idle problems also.. and it was the fast idle valve. it's the black looking cylinder right behind the intake manifold with coolant hoses connected to it. I had to soak it in carbon cleaner and after it was cleaned and dried up.. my car idled fine with a little fine tune of the idle screw.
Old Sep 15, 2003 | 03:44 PM
Default Re: (accordfreak)
Thank you so MUCH!
I wil do it this evening! I will buy you a or if I meet you one day!
Old Sep 16, 2003 | 08:46 PM
Oh man .... the problem came back!! I remove the egr valve, and wash it real clean ... put it back in! The car run fine. After 5 miles on the country, I try to run on high speed .. the motor just ....tooooooooooooom....rpm drop, speed drop ! just like the previous problem. until I have to unplug the EGR sensor harness ... and drive it home with the engine check light on.
Old Sep 16, 2003 | 09:05 PM
BluLude's Avatar
shouldnt be egr valve if you want to check it unplug the vacuum hose that goes into the egr valve and see if it makes a difference, also check the code on the ecu that will tell you the problem...
Bottledh22
Mar 1, 2008 01:03 PM
Villenurve
Oct 12, 2007 09:58 AM
hyspeed1
Apr 1, 2007 04:31 PM
h22a1300177
Sep 16, 2003 08:49 PM
yellowbuffalo
Feb 8, 2002 07:21 PM
