f22 tranny to h22 tranny
Old 04-28-2009, 03:32 PM
rico892002's Avatar
Default f22 tranny to h22 tranny
hi guys i have a boosted f22 vtec motor in my accord with a f22 tranny. i went to the track and i really didnt get good times, many of my friends say my f22 tranny gear ratio is too long. and i was thinking bout buying a jdm h22 tranny. what do u guys think
Old 04-29-2009, 09:56 AM
rico892002's Avatar
Default Re: f22 tranny to h22 tranny
anyone
Old 04-29-2009, 09:09 PM
street_ride14's Avatar
If you are over 300whp, keep your f22 tranny. If you are lower than 300whp, get an h22 tranny. I did the opposite of what you're trying to do .. went from a JDM H22 ( no LSD ) to a F22 ( Prelude S ) tranny, mainly because I wanted to stay in boost longer. I am also above 300whp, so it is your call. .. H22 trannys are short in gears, so it is very annoying having to switch every few seconds, almost seems like you're not taking full advantage of Boost. ..Another tranny, the Prelude H23, is a nice intermediate to consider, will also bolt right up.
Old 04-30-2009, 09:59 AM
rico892002's Avatar
yea it just feel like the f22 tranny is just too long. im really think about switching to a h22. its really hard trying to find a h23 that is mint.
Old 08-16-2009, 07:23 PM
rico892002's Avatar
anyone else, need more suggestion.
Old 08-16-2009, 08:14 PM
B20luda's Avatar
id do the h22 tranny reguardless of power level.. shorter closer gears
Old 08-16-2009, 09:46 PM
H22Honda98's Avatar
x2 who else has experience with this?
Old 08-17-2009, 07:01 AM
twkdCD595's Avatar
Whats your power level? What was the breakdown on the run your friends deemed would be solved by a transmission change.
I personally stuck with the f22 trans but I am making plenty of power to pull it. I like the long gearing for staying in boost and on my drag radials with my slightly higher redline I dont have to shift out of 4th gear going thru the traps.
I dont know if I would agree about any power level. If you have enough power to pull the long gear I would rather run it and not have to shift every 2 seconds. Also the lower redline on the f series combined with a short h series trans, means a huge drop in mph per gear. You will be shifting in to 5th unless your running a tall tire.
Old 08-17-2009, 11:34 AM
rico892002's Avatar
twkdcd595 im on on 10psi, i will be turnin it to 12psi soon and addin a bisi turbo cam in a few weeks. i also shifted at like 7000-7200. will this set up benifit with the h22 tranny?
Old 08-18-2009, 03:32 PM
rico892002's Avatar
bump
Old 08-18-2009, 03:44 PM
H22Honda98's Avatar
does staying in boost longer, or shorter gearing (pending traction), equal a faster car? i see this subject come up all the time and it always seems to be a matter of opinion. does anyone actually have facts??
Old 08-18-2009, 04:01 PM
rico892002's Avatar
yea i need some facts, i kno someone out there have tried it
Digga4
06-11-2005 02:45 PM
95accordh22a
04-09-2005 05:27 PM
o2 jockey
02-16-2004 06:23 AM
JDMpianoguy
06-24-2003 07:51 AM
Quick Reply: f22 tranny to h22 tranny
