What would be the purpose of this?
Notice the wires coming off all four corners of the valve cover and one off of the dist. 3 going to the battery.
Any idea?
Re: What would be the purpose of this? (winglessR)
I would guess he likes engine ground. Serves no purpose. He must of had extra wire and didnt know what to do with it..
It's stupid. They are just extra ground cables for the engine. Not necessary. You will create ground loops with this which could induce unwanted ground currents.....
Re: What would be the purpose of this? (EuroITR1689)
If you guys think grounding the engine is not needed then cut the ground wire on your R and see what happens.........
Re: What would be the purpose of this? (ITR-481)
You need 1 thick ground cable for the engine and 1 thick ground cable for the transmission. No more no less....
Who said ground isnt needed?? That's just overkill to put that many ground straps.
Re: What would be the purpose of this? (B18C-EJ1)
Had to be a combonation of extra cables laying around, boredom, a sense of humor, and a Digi Cam??
I have no idea.
M
I have no idea.
M
Re: What would be the purpose of this? (01ITR#700)
...and B movies
Translation from that website:
Recently you tried grounding the fashion. As for use wiring the 8sq for audio, when 3 are connected directly to the battery from the engine head, the power * torque impression improved clearly just this. When you connect near the light/write to in addition to, the light/write becomes bright, when you connect to such as engine compartment and the partition of the interior, it seems that is the various effects volume of audio becomes large and/or with depending upon the pot. Don't you think? in brief electric resistance becoming small, because it reaches the point where electric current flows efficiently it probably is what.
[Modified by Mark27, 8:20 AM 8/12/2001]
Re: What would be the purpose of this? (vaporsi)
ahem.. forgot to mention that it's not my translation work.
I used babblefish
Here is one of the companies that manufactures these kits:
http://www.takakaira.com/performance/tmworks/main.html
I used babblefish
I forgot more about hondas then you will ever know....
Location: hop,skip, and a jump from the city,, new friggin york, USA
1 Post
that's nothing, i have 3 power cables going from my positive battery terminal to my starter, makes is start faster.....
