wierd problems
wierd problems
ok heres the problem. When the car is in neutral idling the idle is really low then when you put it in first but hold the clutch in the idle goes up and it goes up pretty high, higher then normal. Someone said it may be the clutch but idk if it would cause that so anyone know?
Unceasing Measure
Re: wierd problems (hondaracing1)
It's not the clutch, it's an idle valve or a vacuum line or some petty, annoying **** like that. It's a common problem and you shouldn't worry about it .
brian323is
03-15-2010 11:17 AM
baonest1
29
02-08-2004 01:37 PM
