Engine problems. Please read!!
Old Jun 20, 2001 | 04:07 PM
boomslang's Avatar
Default Engine problems. Please read!!
Okay here is the problem. My prelude died when I was just cruising last night. I wasn't boosing. The car lost power and sputtered to a stop.
The car starts up and idles just great. But it will only rev to about 3K and then fall back down to idle speed. When put into gear the motor doesn't have enough power to move the car and the rpms drop to nothing.
The plugs, rotor, distibutor cap and fuel filter have less than 10k miles on them. I checked them out throughly this morning and all look okay. Plugs look normal. I tried a new set of plug wires and it didn't help.
**The car drove okay this moring when the motor was cold, then the problem came back. ** I asked a mechanic at a honda dealer and they didn't know. I disabled all extra elctronics to help find the problem but nothing helped.
I don't have a CEL coming on at all. Please help!!
Old Jun 20, 2001 | 04:53 PM
Silude's Avatar
New User
Default Re: Engine problems. Please read!! (Inlinefour)
How is your clutch. Is it an aftermarket or stock. If your clutch is bad it wont have any power and you can sometimes smell it.
Old Jun 20, 2001 | 05:36 PM
Honda318dx's Avatar
Default Re: Engine problems. Please read!! (Silude)
SI lude.. He said It won't rev to 3k... thats the motor, not the clutch.. It sounds like some God awlful timing problem.. I really wish I could help.. you might wanna check the fuel pressure maybe?? Good luck
Old Jun 20, 2001 | 05:41 PM
Jarrad_r6's Avatar
New User
Ya, I would look into a fuel type problem. Once the motor warms the FI liens it back out. Also there may not be enough fuel to rev above 3K. What is causing it? Beats me!
Old Jun 20, 2001 | 05:42 PM
Honda318dx's Avatar
Default Re: Engine problems. Please read!! (Jarrad_r6)
Im thinking fuel pump..
Old Jun 21, 2001 | 08:23 AM
JG Luder's Avatar
Default Re: Engine problems. Please read!! (Honda318dx)
yup.. I'd say check the fuel pump, or fuel filter for sure.
Old Jun 21, 2001 | 10:15 AM
HuGEN's Avatar
Default Re: Engine problems. Please read!! (JG Luder)
I agree, must be the fuel pump.
Old Jun 21, 2001 | 10:34 AM
ATYPR's Avatar
how many miles are on your car?
Old Jun 21, 2001 | 09:48 PM
Mr. Choi's Avatar
New User
Default Re: Engine problems. Please read!! (FUCATYPR)
hey, inline 4,
all these people say its the fuel pump or they said it could be the pump, they might be right. test your fuel pressure and VOLUME!!! it is important to test the volume of the fuel the pump is spitting because you can have a fuel pump that packs 50 psi of pressure but very little volume of fuel. have both of them checked, and maybe replace fuel filter if its been there for a long time. the problem could be somewhere else too.
Old Jun 22, 2001 | 06:15 AM
ATYPR's Avatar
Old Jun 22, 2001 | 07:51 AM
Senses Fail y0!'s Avatar
I should know better
what about a bad map/mass air flow/o2 sensor? you get a map sensor funked enough and your car will do some crazy stuff. try looking into those sensors.
Old Jun 22, 2001 | 10:12 AM
boomslang's Avatar
Default Re: Engine problems. Please read!! (CiviChriSiR2)
It is a 95 lude, 2.3L dohc non vtec. 70K miles.
Old Jun 22, 2001 | 10:37 AM
ATYPR's Avatar
Do you have cam gears and what brand?
How good did it drive when it was cold?
[Modified by FUCATYPR, 7:42 PM 6/22/2001]
w4kj4k
Apr 30, 2009 09:01 PM
superdat1
May 1, 2008 10:20 PM
Speedz
Sep 10, 2002 06:06 PM
boomslang
Jun 24, 2001 03:27 AM
boomslang
Jun 23, 2001 10:21 AM
