S300 users
Old Jun 24, 2010 | 12:33 PM
chad's Avatar
Moderator
Default S300 users
What do you see as engine coolant temps in normal everyday driving?
i'm seeing 197-206
iat are 120ish....
is this normal?
chad
Old Jun 24, 2010 | 12:37 PM
Turbogixxer's Avatar
Default Re: S300 users
Honda ECU does not log the ECT correctly. It will peak and then not come down. Hondata, Neptune, and ECtune from what I have seen log about the same.
I am 194-198, but I have my fan triggered at 198. On neptune.
Sound like you have a hot engine bay.
Old Jun 24, 2010 | 12:47 PM
chad's Avatar
Moderator
thank you!!
yes engine bay is cooking when i pop the hood...maybe time for a vented hood....hmmmm....
my heat pointer/lazer thing shows temps on the temp sensor at 192...and hoses at 180's....radiator 175....soooo....what do i believe!
Old Jun 24, 2010 | 12:53 PM
Tootsie7944's Avatar
Originally Posted by chad
thank you!!
With water and water wetter (and a TON of underhood heat from keeping my AC on 96 degree days) I'm seeing about 200-220. Once it hits 220 my check engine light comes on and the car won't boost until it cools down like a limp mode effect. My actual guage isn't going past the center line (stock gauge), but I know that it's not super accurate or fast to react either.
Old Jun 24, 2010 | 04:16 PM
Turbo-LS's Avatar
If yoru engine bay is real hot you need to wrap or coat the manifold and DP and vent it as well. i just use spacers on the hinges and it works well. As for temps hot unde the hood will increase engine operation temps. first get under the hood cooler and see where you are at temp wise then if still hot start workin on airflow to the radiator.
you shouldnt b getting to 220. you have an airflow problem and sounds like to small of a fan and are you running a second fan with a/c ?
my temps never go over 200 with a/c on in my dc2. Ive got a spa top mount full a/c and p/s half core radiator mishimoto with a 14" zirgo byond cool fan 2300cfm along with a 12" mishimoto pusher fan on the driver side for the condenser. i noticed 203 tems without the second fan and now only 200 with the second fan.
Old Jun 24, 2010 | 04:28 PM
Got traction's Avatar
i actually just logged mine day before yesterday. ECT was 197.4 degrees, IAT was reading 115-116 degrees.
motor is a turbo d16y8
tbonez
Honda Civic (2006 - 2015)
Dec 7, 2010 09:44 AM
oem_CD5
Jul 9, 2006 06:28 AM
CC2
Feb 3, 2006 03:14 PM
