driver's side firewall access
Old May 12, 2002 | 08:35 PM
mike's Avatar
H-T Order of Merit
Default driver's side firewall access
Does it exist? I can find any place to get through the firewall on the driver's side. I'm running lines for boost and EGT gauges.
Old May 15, 2002 | 07:58 AM
mike's Avatar
H-T Order of Merit
Default Re: driver's side firewall access (mike)
Nevermind, I went through the fender.
Old May 15, 2002 | 02:21 PM
PrecisionH23a's Avatar
the fender? you know... you can drill a hole through the fire wall, thats what i did. its very easy to do.
Old May 15, 2002 | 02:27 PM
94GSRRacer2's Avatar
New User
Default Re: driver's side firewall access (GudeH23a)
same here, I drilled a 1/4" or so hole right between the throttle cable and the cruise control cable, right between the 2, worked fine for me.
Old May 15, 2002 | 05:30 PM
ItzTw's Avatar
Default Re: driver's side firewall access (94GSRRacer2)
There is a little rubber piece in the right wheel well, that is taped onto the existing stuff running threw. Just cut the tape and retape it when you have everyhting fed threw.
Old May 16, 2002 | 12:56 AM
prelude1897's Avatar
Default Re: driver's side firewall access (ItzTw)
I just drilled a hole close to my clutch pedal...Just be careful not to hit anything in the engine bay.....
Old May 16, 2002 | 07:09 AM
once again, how did you run it through the fender?
Old May 16, 2002 | 07:50 AM
laughinxxx's Avatar
New User
I believe that he just pulled the fender lining out and ran them through.
tom2000
Suspension & Brakes
Sep 11, 2009 01:41 AM
IntegraGSR1999
May 31, 2009 04:43 PM
raymoon
Mar 25, 2008 07:21 PM
1zach4
Jul 7, 2004 11:00 PM
96hb
Aug 21, 2003 10:00 AM
