4th ECU reset?
Old May 14, 2002 | 04:08 PM
NONKonformyst's Avatar
Default 4th ECU reset?
Which fuse do I pull to reset? or do I need to disconnect the battery? Thanks.
Old May 14, 2002 | 04:18 PM
laughinxxx's Avatar
New User
Default Re: 4th ECU reset? (95redLUDE)
I just disconnect the battery.
Old May 14, 2002 | 06:14 PM
britlude's Avatar
Default Re: 4th ECU reset? (laughin2.2)
Disconnect battery for a few minutes. Reconnect. Start engine WITHOUT touching the throttle allow to idle for a few minutes. Switch off then restart,
go for a drive and try to use the full rev range.
Alternatively, remove the BACKUP fuse from under the bonnet for a couple of minutes, replace and go for a drive etc.
Old May 16, 2002 | 07:05 AM
MechEng's Avatar
Default Re: 4th ECU reset? (britlude)
The clock/radio fuse under the hood resets the ECU. Much easier than disconnecting the battery especially if you have an alarm.
I don't understand why people say you must let the car idle for a minute then shut it off??
I do understand that the ECU stores fuel maps in its memory so letting the VTEC kick in after a reset is a good idea for peak performance but probably bad for fuel milage.
Old May 16, 2002 | 08:22 AM
bgod's Avatar
Default Re: 4th ECU reset? (MechEng)
disconnecting the battery will do the job.
there is no need to let the car idle and then switch it off. there will only be a slight change with minor bolt-ons for the ecu to read. not major.
disconnect for a few minutes and you're good to go.
bigslimdog
Mar 30, 2004 03:07 PM
philibuster
Sep 9, 2003 11:17 PM
GS-Rcivic
Jan 8, 2003 09:29 AM
b4uagain
Oct 8, 2002 01:35 PM
FroggyR
Mar 10, 2002 05:36 PM
