do i need a Camber kit?
Old Feb 4, 2004 | 05:14 PM
i3luemrld's Avatar
Default do i need a Camber kit?
im gettin Koni yellow and lowering springs that lower me by 1 1/2" on 17x7 rims offset +40mm w/ 205/40R17 on a 93 prelude si, will i need a camber kit and if so what one ive seen engles but they have two different sizes, any ways point is will i need a camber kit and if so what one?
Old Feb 4, 2004 | 05:38 PM
Tekwon-V's Avatar
Default Re: do i need a Camber kit? (i3luemrld)
do all the work, then give it about a week or two to settle then get a full alignment. and look at the spec sheet to determine whether you need the camber correction or not.
make sure the alignment shop has and uses the top-quality machine. laser-based ones... like the hunters.
you WILL NOT know whether you need the kit or not, 'til you get an alignment.
specialty product and ingalls will be a good choice for the lude.
Civic2000EX
Suspension & Brakes
Apr 10, 2007 11:06 AM
J-Ho
Apr 29, 2005 11:44 AM
no show no go
Oct 23, 2004 11:23 PM
TegoDC5
15
Oct 20, 2004 10:01 AM
clutch33
Oct 29, 2003 04:54 PM
