In direr need of help with an overheating problem
i have an over heating problem in my perlude its a 93 prelude si h23a1 its has a bent valve ing the 3rd cylindar that i know for a fact from a compression test all other cylinders are close if not to the same compression the problem is on a weekly bases i have to put more water and coolent into the car and after about a week of driving to school and home about a 1.5 miles everyday the coolent mixture is gone there are no leaks from what i can see and tell so can someone help me also i replace the ratiator cap because someone told me that was the problem but then its still going on so please help me someone
Sounds like your head gasket has started to go, it is probably letting a small amount of coolant into a cylinder and burning it in the combustion process. Do you notice white smoke coming from the exhaust, that's water vapour in the exhaust gases ? That's a tell tale sign the head gaskets going.
there is no white smoke that is coming out the exausht like i said i did a compression test last weekend all are at or near to the same compression except the 3rd cylinder due to a bent valve but i do not see white smoke at all
dude i had the same problem.....Highly recommend getting a new head gasket. I had ppl compression check my motor n everything....couldnt find the leak until oil leaked out on the way to work....i mean all the oil....then the timing belt broke....so definatel get the head gasket cuz that was the problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n0limitzracer916 »</TD></TR><TR><TD CLASS="quote">so its most likely the the head gasket?</TD></TR></TABLE>
from the sounds of it, yes
Also have a look at your oil, is it a slightly milky colour ? that indicates some coolant might be getting into the block and ending up in the oil although it's not always the case and not the only thing to check. But while your lifting the head to renew the gasket, it's an oportunity to get the bad valve in cylinder three corrected indeed all of them if you want peace of mind.
EGKevin209
10
Jun 7, 2011 10:29 PM
1.8T_EG
Oct 26, 2002 10:50 PM
