... car problems... please help... (compression / leakdown test)
Old Oct 16, 2002 | 10:36 AM
1.8T_EG's Avatar
Default ... car problems... please help... blown motor?????
problems :
- burns oil (needs about 1/2 a quart a week)
- burns coolant (need to refill overflow reservoir every 1 1/2 weeks) (can sometimes smell in car)
- white smoke from exhaust (sometimes, esp. at wot)
- light smoke from under the hood
- sometimes hard to keep idle without stalling (stopped happening after going to the darkside)
- lower than expected performance (191whp/165tq, see sig for setup) (i was expecting 220-250whp)
... i have been told that i could be a couple of things... like a cracked headgasket (not blown or i would be overheating right away)... or cracked ring lands (what are these and how can i check if this is the problem? pull the head, right?)... or cracked sleeves...
... i was also told to do both a compression and leakdown test... i was wondering... after doing these two tests... how will i know if there is a problem?... and then once i pull the head to replace the headgasket what should i look for to check the ring lands, piston rings, and sleeves?...
... thanks for taking the time to read... any help is really appreciated... thanks...
[Modified by 1.8T_EG, 12:39 PM 10/16/2002]
Old Oct 16, 2002 | 02:36 PM
filetofit
Guest
Posts: n/a
Default Re: ... car problems... please help... blown motor????? (1.8T_EG)
I was burning coolant for a while because I hadn't used all the nuts ( I know, ) to hold the intake manifold on. Since coolant passes through the mani it was leaking into the #4 cylinder, check your plugs, I had a green #4 plug.
I don't think you can tell if it's broken rings/lands by just pulling the head, I think you have to pull the rods/pistons.
The logic goes if you've got low compression in a cylinder add a teaspoon of oil in the sparkplug hole and recheck. If the compression goes up it's a problem with pistons/rings. If it doesn't it's valve stem seals/guides.
I think sleeves will be obvious once you pull the head.
No blue smoke under WOT though? Hmmmm....
PS Just as an aside, it's fucked up that I started off just wanting to go fast, I end up knowing how to fix damn near everything on my car.
[Modified by filetofit, 11:45 PM 10/16/2002]
Old Oct 16, 2002 | 03:56 PM
1.8T_EG's Avatar
up for the night crew
Old Oct 16, 2002 | 04:06 PM
IntegD's Avatar
New User
If you do a compression check, that can pretty much solve your problems. If they all come out pretty high and within 10-15psi of each other, then you are probably ok. But, if it comes out low it could be a few things. Blown headgasket, cracked ringlands, burnt up valve, or at worst, a cracked sleeve. Once you pull a compression test, you can find out where it is low.
From there, you can get a leakdown performed and this will tell you where exactly you are leaking compression from. After you find this out, you will pretty much pinpoint the problem. Good luck dude....
Old Oct 18, 2002 | 04:54 PM
1.8T_EG's Avatar
problems :
^one last time^
Old Oct 18, 2002 | 06:43 PM
highmilehatch's Avatar
Do a compression test and post your results.
Old Oct 26, 2002 | 10:50 PM
1.8T_EG's Avatar
Default Re: ... car problems... please help... blown motor????? (highmilehatch)
... just did a compression test... here are my numbers
1 : 180
2 : 178
3 : 185
4 : 185
... great numbers, right?... ((makes me feel a little better))... but now i am totally confused about what my problem is... wtf?!?!?... so now what?... like i said before :
problems :
- burns coolant (need to refill overflow reservoir every 1-2 weeks) (can sometimes smell in car)
- white smoke from exhaust (sometimes, but not always, but esp. at wot)
- blue smoke from exhaust (sometimes, but not always)
- light smoke from under the hood (sometimes)
... i have been told that i could be a couple of things... like a cracked headgasket (not blown or i would be overheating right away)... or o-ring... or worn valves or cracked ring lands (what are these and how can i check if this is the problem? pull the head, right?)... or cracked sleeves...
sleepy_hatch
10
Nov 5, 2004 11:40 PM
dutchman5
Aug 5, 2004 02:58 PM
SPOONfdEK
Jun 24, 2004 02:45 PM
VNTEC
May 22, 2004 08:23 PM
1.8T_EG
Oct 28, 2002 08:06 PM
