compression test results.....weird?
Old Dec 9, 2003 | 10:30 AM
DW's Avatar
DW
Default compression test results.....weird?
i did a compression test today. the numbers seem kinda high. what you guys think?
95 H23
66000 miles
completly stock
60 degress outside
engine warmed up to normal temp.
throttle at WOT during test
pulled ecu fuse
brand new tester
all spark plugs removed
results
#1 #2 #3 #4 each cylinder was test 3 times and same #'s
220 220 215 215
these #'s seem really high but at least theyre consistant. what do you guys think?
Thanks,
David
Old Dec 9, 2003 | 11:08 AM
TimeRacer's Avatar
Default Re: compression test results.....weird? (DW)
Carbon buildup on the pistons, though that's quite a bit on a 66k mile engine.
Old Dec 9, 2003 | 11:22 AM
BolivianFuego's Avatar
Default Re: compression test results.....weird? (TimeRacer)
Nah the numbers seem right. 220-240 means your engine is on point and running damn strong.
Old Dec 9, 2003 | 11:42 AM
justanotherlude's Avatar
Yeah, i would say... A lot of carbon buildup? You should do some long period highway trips. Help cleans it out. But it is an h23 Good #'s
Old Dec 9, 2003 | 11:54 AM
Default Re: (justanotherlude)
Why? Added bump in compression. Why would he want to get rid of that?
Old Dec 9, 2003 | 11:58 AM
rocketlude's Avatar
Default Compression
The car will be lower when cold
Old Dec 9, 2003 | 03:24 PM
DW's Avatar
DW
Default Re: Compression (rocketlude)
thanks for the replies. but i dont think its carbon build up because i always use 93 octane. just got back from a 400 mile trip on sunday and when i wind out the engine it doesnt blow out any carbon. so i dunno its runnin fine ...im not worried
thanks,
David
Junkie
Mar 22, 2008 12:21 PM
DRKSol
Jan 18, 2006 08:23 AM
JetSI
Apr 7, 2004 05:57 PM
lewd43
Aug 11, 2003 04:20 AM
Turbolude
Oct 23, 2001 10:46 PM
