Block question.
Old Mar 21, 2005 | 08:54 AM
slownlow90's Avatar
Default Block question.
Im currently running my stock b18a.I have i the process Shot peened pr4 rods crank being turned .10 and honing the block so the walls are fresh.My question is what can I do and whats out on the market to make my block stronger?And what pistons should I run or will stock Ls pistons be ok to run about 12 psi..thank you for your help!!
Old Mar 21, 2005 | 10:12 AM
mrDFWmechanic's Avatar
stock bottom end on a b18a will be able to hold 12psi but there is no telling when there gonna give up. if you were to stregthen the bottom end you should get some eagle rods and some je or arias pistons. try to keep the compression around 9:1 the stock ls compression. do that and maybe a block guard or if your a baller send it to golden eagle to be sleeved
all depends on how much $$ you wanna put into it
h2b_sedan
Sep 30, 2009 11:38 AM
hott95ej2
Sep 5, 2005 07:04 PM
eag36
Aug 13, 2005 10:22 PM
allmotorek8
Apr 11, 2005 12:42 AM
