Question ABout Sprayin k24
Old Sep 6, 2009 | 01:15 PM
gunsmoke's Avatar
New User
Default Question ABout Sprayin k24
Ok well i finally joined you k series heads and i need some advice for new build.. I recently brought a K24A4 BLOCK with just crank off a friend..
The crank was micropolished and balanced already , i took it straight from mechiene shop. Im looking to build a daily driven Nos setup .
I will be daily driven this to work mon-fri and spraying it for money runs on weekends. My questions is -
I plan on BORING the block to 88mm and getting some 88mm pistons about 12.5 compression.. CAN ANYONE RECOMMEND SOME GOOD PISTONS N RODS
THAT CAN TAKE SOME SPRAY?
OR IS 12.5 COMPRESSION TO MUCH FOR SOME SPRAY?
thanks for any1 who willing to give advice
Old Sep 6, 2009 | 01:30 PM
th3pwn3r's Avatar
Default Re: Question ABout Sprayin k24
How much spray are you talking about? A small shot will most likely be just fine with what you have right now and a decent tune.
Erickgonz20
Engine Machining & Assembly
Dec 6, 2015 10:25 PM
GT500FTW
Dec 18, 2012 11:59 AM
ThatKid513
Nov 23, 2008 05:14 AM
allmotorpackage
Nov 9, 2008 11:38 PM
