question on compression test
Old Dec 4, 2002 | 08:06 PM
mikeyvt's Avatar
Default question on compression test
i recentley got my compression done on my cylinders, and they came up 180 all the way across all the cylinders. i have a f22b2. i think stock it 175. is it bad if its a little higher?
Old Dec 4, 2002 | 08:18 PM
Desslok's Avatar
Default Re: question on compression test (mikeyvt)
THat is fine.
Old Dec 5, 2002 | 04:39 AM
dennis's Avatar
Someone correct me if I'm wrong, but I believe it's higher because of carbon buildup. Also the volume of the spark plug (or compression tester) can vary your findings from the rated specs.
Old Dec 5, 2002 | 04:56 AM
urbanlegend21's Avatar
New User
Default Re: question on compression test (dennis)
that's fine, 200 is about average
Old Dec 5, 2002 | 05:26 AM
Desslok's Avatar
Carbon buildup does cause higher readings, but stock spec I think is around 178 and he is getting 180, and you know the accuracy of the gauge isn't the greatest(probably +/- 5%). If 3 were 180 and 1 was 250 or 120, that is when you have to worry.
kornerk12
Oct 16, 2007 05:59 PM
blacklsvtec24
Aug 24, 2007 03:20 AM
Blazeone
Feb 17, 2005 03:18 PM
FrankEXsteiN
Dec 23, 2002 04:46 AM
MechEng
Feb 11, 2002 06:15 PM
