comp test and bleeding clutch?
exaclty how do i do a compression test? do i just screw in the little guage thing and then manually turn the crank and see what its highpoint is? and how do i bleed the clutch? what fluid do i use, just regular brake fluid? thanks guys!
take out your spark plugs, put your finger in the hole, and have a friend crank it over. If you feel alot of pressure on your finger your good.
Seriously though. You have to screw the pressure fitting into the spark plug hole, one person watches the guage while the other cranks it over(disconnect the plug wires so it won't actually start) Once it "hits"* the guage 4 times take a reading. Repeat for all 4 cylinders
*when I say hits I mean that particular piston comes to the top creating pressure and the guage goes up.
scoker83
16
May 12, 2014 07:01 PM
sony224422
Dec 5, 2007 06:28 PM
