ABS light
Old Aug 28, 2001 | 12:37 AM
Rain_man's Avatar
New User
Default ABS light
I just put in new axles, and my abs light is on. I can see the sensors are lined up, but when teh axle turns, the abs wheel sensor ring on the axle doesn't go in a perfect circle. Is that normal?
Old Aug 28, 2001 | 04:12 AM
D's Avatar
D
Default Re: ABS light (Ein)
no, doesn't sound normal. you should be able to pull abs codes the same way as obd codes, check it out with helm.
D
Old Aug 28, 2001 | 04:32 AM
Willard's Avatar
Sounds like a bad axle... the ring should run true.
Will
ivan93egreppin210
Jul 22, 2009 07:27 PM
Brent_02rsxs
Jun 30, 2008 05:24 PM
GraphiteMW
Mar 5, 2007 05:04 PM
Rain_man
Aug 28, 2001 12:28 PM
