ABS light
Old Aug 28, 2001 | 12:38 AM
Rain_man's Avatar
New User
Default ABS light
I just put in new axles, and my abs light is on. I can see the sensors are lined up, but when teh axle turns, the abs wheel sensor ring on the axle doesn't go in a perfect circle. Is that normal?
Old Aug 28, 2001 | 12:28 PM
fixhondas's Avatar
Default Re: ABS light (Ein)
that is not normal and is probably causing your abs light to come on. The ring on the cv joint is a press fit- you may be able to tap it back in to place- if not, you will need a cv joint.
ivan93egreppin210
Jul 22, 2009 07:27 PM
Brent_02rsxs
Jun 30, 2008 05:24 PM
ILOVEGIRLS
Sep 29, 2001 07:29 PM
Rain_man
Aug 28, 2001 04:32 AM
