About to replace the FUEL FILTER...any pointers??
Old May 13, 2003 | 07:00 PM
GODluvsLUDES's Avatar
Default About to replace the FUEL FILTER...any pointers??
4th gen H23A1 engine..when I remove the lines is it going to spit out fuel? etc?? Any suggestions/hints on replacement is greatly appreciated!!
Old May 13, 2003 | 07:30 PM
bump
Old May 13, 2003 | 07:33 PM
3gLudeH22A's Avatar
Default Re: (GODluvsLUDES)
Once you loosen the banjo bolt on the filter a little fuel will spray out...nothing to bad though. Once you do that your fuel pressure will be relieved and you can replace the filter in seconds.
Boostless97Lude
Guest
Posts: n/a
dude, i was like 1/4 of the way down the page, why the hell did you bump it????
Old May 13, 2003 | 07:42 PM
Default Re: (Boosted97Lude)
Because i'm doing it TONIGHT. I needed to get some answers.
Old May 13, 2003 | 07:43 PM
Default Re: (3gLudeH22A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3gLudeH22A &raquo;</TD></TR><TR><TD CLASS="quote">Once you loosen the banjo bolt on the filter a little fuel will spray out...nothing to bad though. Once you do that your fuel pressure will be relieved and you can replace the filter in seconds.</TD></TR></TABLE>
Do you recommend removing the bracket bolts first or the lines?
Old May 13, 2003 | 07:46 PM
BoostedH23a1's Avatar
unscrew your fuel cap 1st... and dont light a match or something while u do it... thats the only pointers u need
Old May 13, 2003 | 07:47 PM
Boostless97Lude
Guest
Posts: n/a
bumping it like 5 lines isn't going to matter that much, patience is a virtue, it was dumb luck that someone repsonded
Old May 13, 2003 | 07:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted97Lude &raquo;</TD></TR><TR><TD CLASS="quote">bumping it like 5 lines isn't going to matter that much, patience is a virtue, it was dumb luck that someone repsonded</TD></TR></TABLE>
Old May 13, 2003 | 07:53 PM
Boostless97Lude
Guest
Posts: n/a
HA!!! you think twice about bumping a post only 30 min old that is only 1/4 way down next time
and no, this is not an abuse of power, rather a learning experience for a new member
94DOHCDELSOL
16
Jan 18, 2011 04:11 PM
magic hat #9
Jan 9, 2009 07:23 AM
HASUNA91
Oct 22, 2007 04:33 PM
vltnolia
Feb 14, 2007 11:24 AM
samdawgsol
May 13, 2002 09:40 AM
