4th gen engine temp.
Old Nov 18, 2002 | 04:20 AM
munscher's Avatar
Default 4th gen engine temp.
This morning I started my car and headed to work. The engine temp slowly got up to the middle, optimal range (3 bars) and stayed there for about 30 minutes. Then one bar drops off (down to 2 bars) signifying that the engine is now running cooler. It stayed this way for the remaining 15 minutes to work with the engine staying mostly around 3k RPMs at about 60 mph or so. Any ideas why it would run a little cold? Ran fine, no problems.... 30F outside.
Old Nov 18, 2002 | 05:37 AM
kevie88's Avatar
Default Re: 4th gen engine temp. (munscher)
Cause it's cold out silly pants..
Old Nov 18, 2002 | 07:32 AM
munscher's Avatar
Default Re: 4th gen engine temp. (kevie88)
I'm thinking my engine would still run at normal temperature... tell me if i'm wrong, i've never noticed my engine running colder in another car during the winter. HOwever, i've never had a digital readout for engine temp. either, its always been a needle, so I have no idea how much temp. difference that largest digital block represents.
Old Nov 18, 2002 | 11:21 AM
Pimpc_04's Avatar
I don't know what done it for but after i replaced the header my temp stays at 2 bars all the time that is the normal operating temp
Old Nov 18, 2002 | 11:53 AM
munscher's Avatar
Default Re: 4th gen engine temp. (Pimpc_04)
Well, from what i hear from other sources, 4th gen temp. gauges aren't the most accurate, i'm guessing b/c of the digital aspect..... but it seems this is normal and within safe conditions....
Old Nov 18, 2002 | 01:11 PM
Si_LuDer's Avatar
did you have the fan/heater on? if you have the heater on I find that it will suck out the hot air and make the engine run a lil cooler.
Old Nov 18, 2002 | 06:22 PM
NONKonformyst's Avatar
in that cold of weather you should be fine running a little lower, just watch out when you start running hot. Then come back and worry. Brrr... 30 is cold, it was 23 out here today.
crazyguy
Nov 8, 2007 12:09 PM
evans
Feb 10, 2007 01:08 PM
aeon
Apr 12, 2004 05:40 PM
MeanGreenEG9
Jan 16, 2003 05:10 PM
