Where do your temp gauges rest while driving?
Old Jan 16, 2003 | 11:21 AM
MeanGreenEG9's Avatar
Default Where do your temp gauges rest while driving?
I noticed driving to work today my temp gauge was about only 1/4 way to H. Usually I'd see it at just below the 1/2 mark.. granted its been cold here lately 20-35 degrees... I still dont see why my engine is running so cold.. could it be a bad thermostat or maybe the cold weather? I know a cooler running engine is better than a hot running engine but i'm wondering if something is wrong.
Old Jan 16, 2003 | 11:48 AM
myhatchrips's Avatar
Default Re: Where do your temp gauges rest while driving? (SlowAssB16a)
a little bit below half.
Old Jan 16, 2003 | 11:58 AM
Perfectionist's Avatar
On the stock temp gauge on my car, the needle just covers the 'bulb' part of the thermometer icon. If you are running cool it could be your t-stat is not closing enough because it's weak. You would also notice a longer than normal warm up time if it was.
Old Jan 16, 2003 | 12:05 PM
10K2HVN's Avatar
i wish mine would run that low..i dunno if its good or bad but just seems a bit too hot at half-way point...mine use to go up and down with cold weather and how fast im was driving...but now it just sits there...
Old Jan 16, 2003 | 12:27 PM
Kataku2K3's Avatar
Default Re: Where do your temp gauges rest while driving? (10K2HVN)
Just bump antifreeze/water ratio... hehehe.. Your motor will take forever to warm up but it will run cooler overall... It should sit at about 1/3 of the way up the gauge... Atleast in between 1/3 and 1/2.... Latez
Old Jan 16, 2003 | 04:15 PM
delslow94's Avatar
Default Re: Where do your temp gauges rest while driving? (Kataku2K3)
yea mine sits little below half durring summer and winter it sits btw 1/3 and 1/2. for what people say those minor mods of radiator caps and fan switches it does definately keep your motor running a little cooler.
Old Jan 16, 2003 | 04:42 PM
advanracing62's Avatar
Default Re: Where do your temp gauges rest while driving? (delslow94)
mine runs about 60 in winter and around 72 or so in the summer... all degrees in celcius.(sp?)
Old Jan 16, 2003 | 04:53 PM
slomofo's Avatar
GDD Member
If you're running a quarter away from H, I would imagine that your engine is overheating.
Check to see if your fan is working, if so, try changing your thermostat and check your oil to see if you have any water in your oil (Ex: white gooey **** on your dipstick) it means that your headgasket is blown.
Old Jan 16, 2003 | 05:10 PM
Default Re: Where do your temp gauges rest while driving? (slomofo)
my bad man.. i meant that it was 1/4 way up from C not H.. i guess i should have explained better.. basically my problem is the motor seems to be running too cold..
Kalen13
Honda CR-V & Element
Jan 18, 2018 11:04 AM
freefall365
Oct 24, 2010 11:30 AM
bigsnorlax
Dec 17, 2008 08:01 AM
Sir_Phobos
Dec 7, 2002 08:45 AM
eastsidemags
Oct 30, 2002 04:40 PM
