Idle Problems- Help needed
Old Jul 4, 2008 | 06:35 PM
T_Blaze's Avatar
Default Idle Problems- Help needed
just got a 04 ninja 250 with 1600 miles on her two days ago. The previous owner only put about 50 miles on her in the past two years. I took the carbs apart and cleaned the jets. everything looked clear. no signs of varnish in the float bowl.
symptom: high idle surge by itself. sometimes come down sometimes not. most of the time, i have to loosen idle screw to bring it back down and hold the throttle to keep her running.
also, tried to find air leak but couldn't find any.
any suggestions? i'm pretty much stumped on this one. any help appreciated
Modified by T_Blaze at 8:33 PM 7/4/2008
Old Jul 4, 2008 | 07:20 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: Idle Problems- Help needed (T_Blaze)
maybe a sticky throttle cable?
Old Jul 4, 2008 | 07:24 PM
GraphiteAccord's Avatar
Default Re: Idle Problems- Help needed (The Hooligan)
vaccum leak. Or possibly need the carbs synced.
Old Jul 5, 2008 | 11:20 AM
T_Blaze's Avatar
bump... pulled the plug and found out she was running rich. adjusted the float and same problem persists.
gsrauto98
10
Apr 13, 2010 07:28 AM
smit9352
May 12, 2008 03:30 PM
johnmorrin
Apr 13, 2008 09:21 AM
EJ7_1998
Mar 6, 2007 08:21 PM
PWRDbyHseries
Oct 18, 2006 05:44 PM
