BUNMANGO's CBR600F4
Old 05-16-2009, 08:36 PM
Blue Hybrid's Avatar
Default BUNMANGO's CBR600F4
Working on buns 600F4... Thuoght it was only the stator cover and rotor that was damaged... until i found this!!!
So i broke out the tig welder...
Day one:
Day two:
Built a weld into the shape where the lower bolt goes. Drilled and tapped
End:
Tomorrow i check to see if it leaks.
His fuel pump and battery are shot...lots of work left to do before its road worthy...
wonder why it wouldnt run... look how dirty it was!
Can someone tell me how to get the jet out? Its pretty stuck. Can you please also help me identify the brass parts?
Updates to come
Old 05-17-2009, 12:54 PM
marmaladedad's Avatar
Default Re: BUNMANGO's CBR600F4
That's some good work! You have your own TiG welder in your garage?
Old 05-17-2009, 01:19 PM
My Name is Nobody
MSchu's Avatar
I don't see that case damage hurting you one way or another... race bikes can actually have the stator removed/modified and a simple plate in that area. maybe the stator itself was damaged?
Old 05-17-2009, 10:11 PM
its his daily so... needs the stator for lights
Old 05-18-2009, 04:32 AM
My Name is Nobody
MSchu's Avatar
but a broken bolt wouldn't preclude that bike from running correctly. there is NO fluid in that section or correlation to function with that cover
Old 05-18-2009, 07:51 PM
Its directly above the oil pan and you can see the crank shaft... i think there is plenty of fluid in there...
Old 05-19-2009, 08:13 PM
BIKE RUNS!!! NO LEAKS! just need a few more parts...
Blue Hybrid
Welding / Fabrication
05-21-2009 06:52 PM
midwesta
05-26-2005 12:54 AM
Bbasso
03-27-2005 04:47 PM
RoaringTurtle
03-02-2005 01:01 AM
Bazza4788
01-27-2005 11:59 AM
Quick Reply: BUNMANGO's CBR600F4
