BUNMANGO's CBR600F4
Working on buns 600F4... Thuoght it was only the stator cover and rotor that was damaged... until i found this!!!
https://farm4.static.flickr.com/3132...56e9c60a_o.jpg So i broke out the tig welder... Day one: https://farm3.static.flickr.com/2436...a419594b_b.jpg Day two: Built a weld into the shape where the lower bolt goes. Drilled and tapped https://farm4.static.flickr.com/3372...d5338c79_o.jpg End: https://farm3.static.flickr.com/2340...40dde7b5_o.jpg Tomorrow i check to see if it leaks. His fuel pump and battery are shot...lots of work left to do before its road worthy... wonder why it wouldnt run... look how dirty it was! https://farm4.static.flickr.com/3389...64133f1c_o.jpg https://farm3.static.flickr.com/2442...c266800c_o.jpg Can someone tell me how to get the jet out? Its pretty stuck. Can you please also help me identify the brass parts? https://farm3.static.flickr.com/2453...084cd84c_o.jpg Updates to come |
Re: BUNMANGO's CBR600F4
That's some good work! You have your own TiG welder in your garage?
I don't see that case damage hurting you one way or another... race bikes can actually have the stator removed/modified and a simple plate in that area. maybe the stator itself was damaged?
Originally Posted by MSchu
(Post 38567381)
but a broken bolt wouldn't preclude that bike from running correctly. there is NO fluid in that section or correlation to function with that cover
(Post 38574069)
BIKE RUNS!!! NO LEAKS! just need a few more parts...
