Engine Light & VTM-4 lights
The engine light came on in my 2006 Honda Ridgeline after I start it and begin driving. Shortly thereaftter the VTM-4 light also comes on and I can't turn it off. Other than that, the truck seems to be running fine. Any idea what's going on with it?
Re: Engine Light & VTM-4 lights
Similar thing happened to me this morning my 2006 Ridgeline. I was driving on my way to work then my check engine light and VTM-4 light went on. When I got to work, I parked my car, turned off my engine, installed my ODB-II reader and started the engine back up. The VTM-4 light turned off but got a P2631 check engine light code. Code P2631 is set by the PCM when the O2 Sensor Pumping Current Trim Circuit for Bank 2 Sensor 1 is sending a higher voltage signal than normal. Bank 2 is the bank of the engine that does not contain cylinder #1. It could be just an intermittent failure. Just clear the code and see if it happens again.
hawjboieg6civic
07-04-2010 03:08 PM
