HELP CAR WONT START!
Old Apr 25, 2007 | 06:32 PM
b16a4's Avatar
Default HELP CAR WONT START!
I have a originak ek4, b16a engine.
The car wont start,
Has spark from plug wires,
Has fuel, unplugged fuel rail line and started car..
car was parked for about 1 day, and just wont start now.
PLEASE help me guys!
Old Apr 26, 2007 | 03:07 PM
Lucky-13's Avatar
Default Re: HELP CAR WONT START! (b16a4)
is the fuel pump priming?? If not check the main relay.
Check the grounds to the thermostat, check the valve cover ground, battery ground....make sure the ecu is connected correctly....is the CEL on and what code are you throwing??
Old Apr 26, 2007 | 04:15 PM
slomofo's Avatar
GDD Member
Do you have compression? Did the rotor fall off of the distributor (common problem)? Alarm? Immobilizer? Main relay good?
Old Apr 26, 2007 | 06:21 PM
b16a4's Avatar
Default Re: (slomofo)
thanks for the response guys.
somehow my timing jumped and the car wasnt getting enuff compression 2 start
Active EF
Feb 21, 2015 08:56 PM
civic efb16
Aug 8, 2005 09:00 PM
delphi-dada
Apr 5, 2005 04:09 AM
illestrolla247
Apr 4, 2005 06:24 PM
