will jdm corners mate with usdm headlights
Old 09-29-2009, 12:05 AM
JDMJUNKIEMONKIE's Avatar
Default will jdm corners mate with usdm headlights
im looking to purchase some jdm ef hatch corners, does it matter what year? also will it just be a complete bolt on no modifications needed. Thanks.
noob to the ef game.
Old 09-29-2009, 12:18 AM
alx_90ef's Avatar
Default Re: will jdm corners mate with usdm headlights
its their from an ef9 front end...
im not sure that they will
i heard they dont but im not 100% sure..
but some people put JDm as if it makes the lights any better.
their most likely usdm
what year is your ef?
cuz 88 89 screw on to the fender and 90 91 screw on to the head light bracket
Old 09-29-2009, 12:39 AM
my car is a 89 civic. has screws on the corner lights. but the corner lights i got dont have screws on the corner light.
Old 09-29-2009, 05:40 AM
dcvt16's Avatar
if you have 90-91 headlight brackets and the tabs on the fender from 90-91 (the ones that slide in, not screw in) they will work. line up just fine.
Old 09-29-2009, 06:09 AM
chililpuppet's Avatar
88-89 have screws on the side of the corner lights
90-91 has tabs on the inside of the lights
so just check to see if the one's you are going to buy have what you need
Old 09-29-2009, 07:20 AM
apekd's Avatar
if they are from a different set of years (IE if you have a 88 (89) and its a 90 (91) corner light) just switch the head light brackets and they will fit just fine.
Old 09-29-2009, 07:35 AM
akshn1's Avatar
u can put any year...i have a 88 and put 90 corners..just changed the lil tabs inside
Old 09-29-2009, 07:42 AM
mitsubishiv5's Avatar
they'll work
and it doesnt really matter if its 88-91. itll still fit if you get the little plastic tabs to screw into. itll be a awkward fit, but atleast youll have corner lights on. not to mention having a busted up radiator support makes things even harder.
ghosthatch
05-15-2010 12:07 AM
Big Skeet3817
09-11-2009 09:12 PM
anj_jmv
21
10-20-2007 04:47 PM
92integra_gs
11
10-06-2004 04:15 AM
Quick Reply: will jdm corners mate with usdm headlights
