will jdm corners mate with usdm headlights
im looking to purchase some jdm ef hatch corners, does it matter what year? also will it just be a complete bolt on no modifications needed. Thanks.
noob to the ef game.
Re: will jdm corners mate with usdm headlights
its their from an ef9 front end...
im not sure that they will
i heard they dont but im not 100% sure..
but some people put JDm as if it makes the lights any better.
their most likely usdm
what year is your ef?
cuz 88 89 screw on to the fender and 90 91 screw on to the head light bracket
my car is a 89 civic. has screws on the corner lights. but the corner lights i got dont have screws on the corner light.
if you have 90-91 headlight brackets and the tabs on the fender from 90-91 (the ones that slide in, not screw in) they will work. line up just fine.
88-89 have screws on the side of the corner lights
90-91 has tabs on the inside of the lights
so just check to see if the one's you are going to buy have what you need
if they are from a different set of years (IE if you have a 88 (89) and its a 90 (91) corner light) just switch the head light brackets and they will fit just fine.
1 Post
they'll work
and it doesnt really matter if its 88-91. itll still fit if you get the little plastic tabs to screw into. itll be a awkward fit, but atleast youll have corner lights on. not to mention having a busted up radiator support makes things even harder.
ghosthatch
05-15-2010 12:07 AM
Big Skeet3817
09-11-2009 09:12 PM
