Where can i get everything for a dpfi to mpfi conversion??
I was wondering where can i get everything for a dpfi to mpfi conversion??
Simply what do i nedd, where do i get it, and how much?
thanks
thanks
Re: Where can i get everything for a dpfi to mpfi conversion?? (lephem)
Parts you need:
1-Complete si manifold
2-injector resistor box
3- si distributor
4- si ecu
You should be able to find all of the parts you need on ebay. Also there are alot of good write-ups on dpfi-mpfi conversions here on honda-tech. Just search a little.
3- si distributor
4- si ecu
Re: Where can i get everything for a dpfi to mpfi conversion?? (likaciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by likaciv »</TD></TR><TR><TD CLASS="quote">Would i need the resistor box if i was running obd-1 gsr injectors? </TD></TR></TABLE>
Nope you would just twist all the yel/black wires together. Im pretty sure its the yel/black cant remember since its been so long.
Re: Where can i get everything for a dpfi to mpfi conversion?? (92integra_gs)
Injectors and injector resistor box
Connect the yellow/black wires from the two DX injector harnesses and run it to the yellow/black wire on the injector resistor box.
Connect the yellow wire from the DX injector to the #1 injector (brown wire).
Connect the red wire from the DX injector and run it to the #3 injector (blue wire).
Connect the A3 wire to the #2 injector (red wire).
Connect the A7 wire to the #4 injector (yellow wire).
Connect the 4 red/black wires from injector resistor box to each injector.
That is for resistor box applications, since those wires are a switched 12v anyway, the two new injectors would just connect to the yellow/black wires of the existing two injectors, correct?
dem0nk1d
06-20-2007 04:44 PM
