obdo-to obd1 conversion
Old Dec 27, 2004 | 09:17 AM
my crx is rhd's Avatar
Default obdo-to obd1 conversion
i have the hondata s100 p28 ecu, i got the distruibutor, but do i need the 4wire o2 sensor, or will the s100 take care of that? and what about the resistor box, obd1 doesn't require that, so what do i do with that?...anything else that i'll need for my turbo rex?
Old Dec 27, 2004 | 10:51 AM
tgreaves's Avatar
Default Re: obdo-to obd1 conversion (slammed91integra)
Youll need the resistor box if your injectors are low-impedance.. If your using your old injectors and there wasnt a resistor box there before then your dont need one now..
Old Dec 27, 2004 | 01:57 PM
VTech4President's Avatar
I am thinking you will have to do some injector re-wiring
Old Dec 27, 2004 | 06:15 PM
eda6's Avatar
Default Re: obdo-to obd1 conversion (VTech4President)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Youll need the resistor box if your injectors are low-impedance.. If your using your old injectors and there wasnt a resistor box there before then your dont need one now..</TD></TR></TABLE>
I agree if the injectors were untouched you'll be fine.
Low impedance (peak/hold) 1.5-2.5 ohms resistance (needs resistor box)
High impedance (saturated) 13-18 ohms resistance (no resistor box)
Old Dec 27, 2004 | 09:34 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed91integra &raquo;</TD></TR><TR><TD CLASS="quote">i have the hondata s100 p28 ecu, i got the distruibutor, but do i need the 4wire o2 sensor, or will the s100 take care of that? and what about the resistor box, obd1 doesn't require that, so what do i do with that?...anything else that i'll need for my turbo rex?</TD></TR></TABLE>
If you are going to run in open loop, you do not need an O2 sensor. Do you have the OBD0-1 harness yet?
Old Dec 28, 2004 | 06:34 AM
Default Re: obdo-to obd1 conversion (Blown90hatcH)
i have an obd0 harness, we spliced in the dist. plugs, and questioned the o2 situation. i have rc 550's from a 99 si civic...they plugged right in...
Old Dec 29, 2004 | 07:26 AM
can i run the s100 in an open loop setup?
Old Dec 29, 2004 | 07:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed91integra &raquo;</TD></TR><TR><TD CLASS="quote">can i run the s100 in an open loop setup?</TD></TR></TABLE>
And not have a 4 wire O2 sensor?......Yes you can.
Old Dec 29, 2004 | 09:13 AM
thanks man, any other ideas of anything i might need to do?...with this wiring setup for this conversion?
91EF919
Oct 9, 2008 06:34 PM
immorality
May 24, 2008 03:46 PM
RudeLude
Apr 22, 2006 07:36 AM
7rrivera7
Jan 17, 2005 02:07 PM
Butch
May 16, 2003 08:49 AM
