Valve gasket replacemant
Re: Valve gasket replacemant
You usually just remove the valve cover. Go on to autozone and sign up and go into the repair section you can use there repair manuals for alot of work.
A valve cover gasket is pretty self explanatory. All the bolts are right in front of you. Just go to autozone and pick up a valve cover gasket kit with new grommets and you should be good to go.
PHANTOM MENACE
Yeah, hand tight is all you need. I think the spec is something like 20ft-lbs, too low for most torque wrenches. If you don't have a smaller (lower reading) torque wrench, grab a ratchet, grab it by the center of the big end (not the handle) and tighten the valve cover bolts that way.
