importance of properly torquing the valve cover?
New User
i stupidly went to pull my valve cover today... took all the bolts out, etc etc and then realized that i wouldn't be able to get it off (due to other things in the way that i wasn't willing to remove.)
and then, more stupidly, i realized that i didn't have any liquid gasket OR my torque wrench!!!!! (left it elsewhere.)
so i just put it back on and guesstimated. the torque listed in the helms for those little guys is really low... but it seemed like even with a small amount of force on the socket wrench they just kept turning. i didn't want to strip anything, so i stopped after a while.
what's the worst case here? i drove a bit, no leaking oil or anything. if it's not 100% sealed, is a bit of lost oil the worst that can happen?
[ashamed]
thanks in advance
[ashamed]
thanks in advance
Re: importance of properly torquing the valve cover? (schwett)
it should be fine. Last time I pulled my valve cover we just tightened the bolts "tightly" and didn't need any gasket sealant. No problems here.
1 Post
Re: importance of properly torquing the valve cover? (Pyrochaos38)
not too tight though, cause you can cause it to crack.
Yeah, worst case, you leak a little. Wah. You're good to go.
Re: importance of properly torquing the valve cover? (JG Luder)
I forget what the torque is, but it's really low. Below what most torque wrenches will do. If you do them too tight, the just strip them. Too loose isn't a big deal.
Re: importance of properly torquing the valve cover? (DirtyLude)
Just make sure to tighten them snug. I broke one bolt off once and had to run to the dealer to get a whole new stud. After that, my gasket wasn't aligned correctly and I was leaking oil onto my intake manifold. I drove around for about 30 mins when I realized there was smoke pouring out of my hood!
Drove back home, realigned the gasket then tightened the cover snug. It was good then.
A LITTLE leak isn't bad, but a huge leak is a big problem. But since you didn't take off the cover, you should be okay.
