tps screw broke off in throttle body need help!
i noticed on my throttle body when me and my friend swapped a 92 ls motor , the tps had a bolt broke off into the throttle body and its only in there by one bolt now but its all set to oem specs and stuff , but would just having one bolt holding it on make my car run funny???
Re: tps screw broke off in throttle body need help! (bbrian)
Remove the other bolt and replace both of them at the same time.
If the bolt isn't broken flush with the TB then you acn just turn it out.
the bolt is broken inside the t/b and would it make the car run like crap like this ???
You would get a code 7 if your TPS wasn't reading the correct voltage from being out of adjustment.
You can fix it by removing the tps, drilling out the old screw and retapping the hole 1 size up
Re: tps screw broke off in throttle body need help! (Autoworks)
alright thanks cause my cars keeps boggin down when i drive it and its throwin no codes at all any suggestions any one , im gonna try and clean my iacv and see what that does , and my stupid alt belt broke off the other day too
i dunno what could be the prob then lol , ive tryed to think of everything , its not throwin any CEL or nothing ??? im just gonna still try to clean the iacv out cause the screen in it looked real black
Vp Special K
04-08-2003 07:58 PM
