How do i remove the tps from the throttle body?
im having trouble removing the tps off the throttle body. Whats the easiest way to do this?
Re: How do i remove the tps from the throttle body? (Vp Special K)
ill sell you my jdm throttle body. haha, but im serious, the tps is bolted on, not riveted.
if you want to, ill give you the tps, and the 2 bolts, and you can just hack the old one off, and tap 2 holes to bolt mine into. you can have it if you pay for the shipping.
*edit- you don't have to drill or tap the holes, just find screws that'll fit the thread.
[Modified by Loco Honkey, 12:20 AM 4/9/2003]
Re: How do i remove the tps from the throttle body? (Loco Honkey)
you sure they are rivits? i could swear they were a star bolt.. and you need to know how to adjust it when you put it back on
Re: How do i remove the tps from the throttle body? (drunknbass)
Use a hack saw or a Dremel tool and cut slots in the top of the "rivets" that hold the TPS on, and unscrew them. When reinstalling the TPS, use normal screws w/ washers.
the TPS does not use rivets.....they are simply SCREWS with the heads cut off.....just cut a slit at the top of the head, and unscrew it with a flathead screwdriver...voila
stackz
10-04-2006 07:06 AM
