Searched with no luck. B16 dies during cold idle.
Old 03-01-2005, 04:57 PM
kim_2_da_chee's Avatar
Default Searched with no luck. B16 dies during cold idle.
I've searched "idle" and 4 pages came up. However none of the threads seems to be describing what my problem is.
Let me start with these points:
-new battery
-cleaned out IACV with brake cleaner and varsol (clean as a whistle now)
-screwed in the FITV fully
-no vacuum leaks
-no fluctuating idle
-new distributer
-new spark plugs
-no codes
So here is the problem:
- I start my motor, it starts with a little more cranking than usual (cold weather).
- After about 5-10 seconds, the RPM slowly drops until the motor cuts out.
- I start it again, and it does the same thing
- So this time as soon as I started the motor, I tried giving it some gas, but as soon as I touched my gas pedal.... the motor died.
This is a cold idle, so I checked the engine oil and it's fine.
I took off the FITV again to check if I need to screw it in again, but it was still fine. I can't seem to figure out what the problem is. TPS maybe? How would I be able to "check" it?
Please help!
Old 03-01-2005, 05:31 PM
Burlyirishdude's Avatar
Default Re: Searched with no luck. B16 dies during cold idle. (kim_2_da_chee)
You need a new coolant temp sensor.....a TW sensor....check to see if you're throwing a code 6....I was throwing that and i fixed it and now the motor start right up no dying....good luck
Old 03-01-2005, 10:09 PM
Default Re: Searched with no luck. B16 dies during cold idle. (Burlyirishdude)
Where is this located?
How much is it at Honda?
Is it a pita to replace?
thanks
Old 03-01-2005, 10:38 PM
xxscaxx's Avatar
check out the TPS. as far as checking it, unless you bring it somewhere or have like a helms manual, you just have to play around with it. just move it little by little.
Old 03-01-2005, 10:39 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burlyirishdude &raquo;</TD></TR><TR><TD CLASS="quote">You need a new coolant temp sensor.....a TW sensor....check to see if you're throwing a code 6....I was throwing that and i fixed it and now the motor start right up no dying....good luck </TD></TR></TABLE>
i had no problem starting my car with the coolant temp sensor unplugged.
Seems like a fuel problem to me.
Old 03-01-2005, 11:03 PM
Default Re: Searched with no luck. B16 dies during cold idle. (eda6)
Fuel problem indeed.
Well, I just found out that my fuel gauge is faulty. Since my fuel gauge was just above the red mark, I didn't think that I was out of fuel. I added in some fuel and she started right up. on me.
However, the motor still does this:
- at intial cold start, the idle is at 700 RPM (really low IMO for a cold motor)
- If I try to give it some gas, the motor would cut out
- If I leave it for 5 mins, the RPM slowly rises to 1500.
- Then I am able to drive.
- Also, at warm/hot idle, you can hear "sputtering" from the exhaust. (it doesnt sound too healthy)
Anyone know what that problem might be?
Thanks
Old 03-02-2005, 12:02 AM
Wink1100's Avatar
check your fuel pressure. also your fuel pump. run a couple test. I know an OEM Honda pump runs a lower PSi rating compared with an Integra fuel pump. Most people I know, sometimes have this problem. I had a friend with an EG w/ a B16 and he solved his problem with an aftermarket fuel pump.
Spoon-Integra
04-22-2009 11:59 AM
omg_jdm
02-26-2009 07:23 PM
skata89
05-21-2006 06:23 AM
NJAman
01-17-2005 10:19 PM
B00ST2nR
08-28-2002 02:16 PM
Quick Reply: Searched with no luck. B16 dies during cold idle.
