is it safe to have a hydro clutch in a cable tranny for a b series motor
Old Aug 19, 2006 | 07:10 PM
efcivic12's Avatar
Default is it safe to have a hydro clutch in a cable tranny for a b series motor
i have a 1990 ef with a ls motor and i have the cable trans and supposedly a hydro clutch in it is this possible and is this safe
Old Aug 19, 2006 | 08:27 PM
DC_RaceR's Avatar
Default Re: is it safe to have a hydro clutch in a cable tranny for a b series motor (efcivic12)
I don't think it'll fit.
You have to use what was made for the tranny.
Hydro to hydro
and
cable to cable.
One of them is a little bigger if I remember right.
Old Aug 19, 2006 | 09:07 PM
lightcrx's Avatar
only differance is the disc. pp and flywheel are the same
-joseph
Old Aug 19, 2006 | 10:45 PM
E_F_9's Avatar
my friend used a hydro clutch in a cable ls tranny and it worked/works fine
Old Aug 19, 2006 | 10:47 PM
bag's Avatar
bag
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efcivic12 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 1990 ef with a ls motor and i have the cable trans and supposedly a hydro clutch in it is this possible and is this safe</TD></TR></TABLE>
yeah as long as the tranny you have is 92-93..92-01 b-tranny use same clutch but different throwout bearing..if you got 90-91 tranny you gotta use 90-91 clutch
Old Aug 20, 2006 | 12:10 PM
efcivic12's Avatar
ok thanx guys
Old Aug 20, 2006 | 01:04 PM
Loserkidwac's Avatar
90-91 same spline count but thinner, the 92+ discs are all the same hydro or cable and they will fit over the 90-91 input shaft but can damage the shaft because of the loose fit...as for the flywheels its the same 90-91 have different flywheels and 92+ are all the same
Old Nov 8, 2008 | 07:05 AM
turboef90's Avatar
back from the dead!!how noticeable is the play when you put 92 plus plate on a 90 91 tranny???
Old Nov 8, 2008 | 07:33 AM
blakkvtec's Avatar
Default Re: is it safe to have a hydro clutch in a cable tranny for a b series motor (turboef90)
^^^Shouldn't even fit. Different splines I thought?
Old Nov 8, 2008 | 07:40 AM
turboef90's Avatar
Default Re: is it safe to have a hydro clutch in a cable tranny for a b series motor (blakkvtec)
they will fit. but the 90 91 plate will not fit on the 92+ tranny
cccballa
Jan 12, 2009 09:39 PM
dcasti2345
Jul 26, 2007 06:22 PM
civicandy
Sep 1, 2006 11:26 AM
synner
Aug 6, 2006 12:09 PM
